Idea for bigger displays
A project log for Omnidirection display
This display does an impossible task ! it keeps the image ALWAYS facing the spectator whatever the angle of observation !
SalahSalah 06/14/2021 at 04:280 Comments
The speed of rotation is high in order to have a stable image without flickering.
That was easy for the lightweight and small Pringles can but if we want to display bigger images, the speed of rotation will cause problem.
One solution is to use multiple cylinders as shown in the following figure.
Each cylinder containing the exact same image.
In the example shown, there is 6 cylinders so we can lower the rotation’s speed 6 times.
