Other useful frequencies
A project log for ATtiny12L Selectable Frequency Generator
A low-power selectable frequency generator
scottScott 02/06/2017 at 08:310 Comments
I decided to post some other useful frequencies that I have run across that others have verified seem to have positive effects. They are listed below. Note that the ATtiny12-based frequency generator described in this post is only capable of generating fixed frequency output. Perhaps adapting the code to implement a direct digital synthesis (DDS) sweeping method would allow one to obtain the resulting frequencies. Keeping in mind that the chosen DDS “sampling frequency” would limit the upper frequency range. Another choice may be to use an external DDS IC with a square-wave output, such as the ANALOG DEVICES AD9837, which uses an SPI interface.
Description
Frequency (Center or Low)
Frequency (High)
Delta F
Type
Duration (in minutes)
Step Rate (250mS/step):
Number of Sweeps (up and down)
Love
13,824
fixed
21.00
1
84
Virus/Parasite Sweep
350,000
490,000
250
sweep
70.00
10
3
Bacteria Sweep
285,000
390,000
250
sweep
52.50
6
5
Molds and Mildews Sweep
75,000
300,000
400
sweep
56.25
8
3
Candida Sweep
435
495
5
sweep
30.00
12
50
Lyme Sweep
28,000
29,000
50
sweep
50.00
12
50
Fibroid Cyst Sweep
990,000
1,150,000
250
sweep
56.00
7
3
General Pain Reliever
16,936
fixed
60.00
1
240
Tissue Regeneration
565
fixed
60.00
1
240
“Sticky” Blood Sweep
62,500
67,500
50
sweep
26.67
16
4
Cellular Recharge
880
fixed
60.00
1
240
Cramps
111
fixed
30.00
1
120
Solfeggio – Angelic Skein
111
1,555
111
list
30.00
1
553.5
Glaucoma Sweep
12,728
12,828
10
fixed
45.33
16
68
Here are some “experimental” frequencies that I ran across.
Description
Frequency (Low or Fixed)
Frequency (High)
Delta F
Type
“Clark” Sweep
2,250
2,750
15
sweep
45.00
12
27
Thyroid De-calcify
122,300
123,300
77
sweep
30.84
15
38
Blood Pressure Reduction
77,525
fixed
60.00
1
240
Type 2 Diabetes
122,080
123,080
11
sweep
28.41
15
5
Pineal Gland De-calcify
121,550
122,050
27
sweep
30.56
11
36
Mites Sweep
641,000
781,000
280
sweep
62.50
6
5
Auto-Immune Strengthening
140
200
5
sweep
30.40
16
38
Charged Water
150,000
fixed
30.00
1
120
Food Poisoning
12,484
fixed
30.00
1
120
Kidney Stone Passing
999
fixed
90.00
1
360
Energy Sense Ability
500
1,500
50
list
48.00
1
576
3rd Eye, Crown, Crown+1, Crown+2
852
1,285
111
list
16.00
1
984.5
Libido Elevation
80
90
10
list
15.00
1
3600
Energy Transfer Block
77,777
fixed
90.00
1
360
