30 days of temperature and humidity readings
A project log for Freezer kiln for wood drying
I'm making a small freezer into a kiln for drying wood bowl blanks.
KevinKevin 07/25/2021 at 16:280 Comments
30 days of temperature and humidity readings, on the same window as the "weight" graph in the other log entry.  The blue line here is the ambient sensor from outside of the kiln, whereas the green and yellow are at 2 different places inside the kiln.
