I2C Front Panel Control
A project log for Small CPU in VHDL
Small CPU in VHDL
land-boardscomland-boards.com 07/07/2021 at 20:220 Comments
There are several other IOP16 demos that use the Land Boards Front Panel I2C card. The Hackaday page for the Front Panel is here.
The code controls the four MCP23016 parts. These are 16-bit I2C parallel I/O expanders. The advantage using the Land Boards Front panel card is it only uses 2 FPGA I/O pins to read 32 pushbuttons and write 32 LEDs. The IOP16 runs the Front Panel I2C interface. The GitHub for the Front Panel example is here.
There are three examples so far.
There's also an example for Multicomp which controls an M6800 CPU running MIKBUG. This is a fully functional Front Panel example.
