Building the big table
A project log for OpenWorkbench
Easy to build workbenches, that you can hand a cut-list to the big-box-store and assemble at home with glue and screws and simple tools
Peter van der WaltPeter van der Walt 06/21/2021 at 20:220 Comments
Got the local Builder Warehouse to cut the pieces to size for me, and set about glueing and screwing together (:
Ran a
Ran a roundover bit in a router over all the corners, and give it a light sanding just to make it all nicer (:
