Step 6. Creating assistant.js
A project log for GUILLENGAP Cobot
Collaborative Robot Arm with Artificial Intelligence, and Used as Assistant in: 1) Voice Command System & 2) Sorting Objects System
guillermo-perez-guillenGuillermo Perez Guillen 06/28/2021 at 02:150 Comments
This step will go show you how to setup a MATRIX Lite project with Snips.
First, MQTT must be installed and used to listen in on events from Snips.
npm install mqtt --save
assistant.js will be used to listen and respond to events from your Snips assistant. This file combines all the code from everloop.js & relay.js to control the everloop and relay switch through voice.
//AUTHOR: GUILLERMO PEREZ GUILLEN//
//VARIABLES//
var mqtt = require('mqtt');
var client  = mqtt.connect('mqtt://localhost', { port: 1883 });
var relay = require('./relay.js');
var everloop = require('./everloop.js');
var snipsUserName = 'guillengap';
var wakeword = 'hermes/hotword/default/detected';
var sessionEnd = 'hermes/dialogueManager/sessionEnded';
var lightState = 'hermes/intent/'+snipsUserName+':roboticArmState';
//ON CONNECT//
client.on('connect', function() {
   console.log('Connected to Snips MQTT server\n');
   client.subscribe('hermes/hotword/default/detected');
   client.subscribe('hermes/dialogueManager/sessionEnded');
   client.subscribe(lightState);
//ON MESSAGE//
client.on('message', function(topic,message) {
   var message = JSON.parse(message);
   switch(topic) {
       // * On Wakeword
       case wakeword:
           everloop.startWaiting();
           console.log('Wakeword Detected');
       break;
       // * Robotic Arm Change
       case lightState:
           // Turn robotic arm Here/There
           try{
               if (message.slots[0].rawValue === 'here'){
                   relay.roboticarmHere();
                   everloop.stopWaiting();
                   console.log('Robotic Arm Here');
               else if(message.slots[0].rawValue === 'there'){
                   relay.roboticarmThere();
                   console.log('Robotic Arm There');
           // Expect error if `here` or `there` is not heard
           catch(e){
               console.log('Did not receive an Here/There state')
       break;
       // * On Conversation End
       case sessionEnd:
           console.log('Session Ended\n');
       break;
 everloop.js incorporates the code required to control the LEDs on the MATRIX Creator.
//VARIABLES//
const matrix = require('@matrix-io/matrix-lite');
var matrix_device_leds = 0;// Holds amount of LEDs on MATRIX device
var methods = {};// Declaration of method controls at the end
var waitingToggle = false;
var counter = 0;
setInterval(function(){
   // Turns off all LEDs
   if (waitingToggle == false) {
           // Set individual LED value
           matrix.led.set({});
   // Creates pulsing LED effect
   else if (waitingToggle == true) {
           matrix.led.set({
               b: (Math.round((Math.sin(counter) + 1) * 100) + 10),// Math used to make pulsing effect
   counter = counter + 0.2;
   // Store the Everloop image in MATRIX configuration
},50);
//WAITING METHODS//
methods.startWaiting = function() {
   waitingToggle = true;
methods.stopWaiting = function() {
module.exports = methods;// Export methods in order to make them avaialble to other files
relay.js includes the code required to turn the robotic arm here and there. This relay will control power to the robotic arm.
//VARIABLES//
matrix.gpio.setFunction(0, 'PWM');
matrix.gpio.setFunction(1, 'PWM');
matrix.gpio.setFunction(2, 'PWM');
matrix.gpio.setFunction(3, 'PWM');
matrix.gpio.setFunction(4, 'PWM');
matrix.gpio.setFunction(5, 'PWM');
matrix.gpio.setMode(0,'output');
matrix.gpio.setMode(1,'output');
matrix.gpio.setMode(2,'output');
matrix.gpio.setMode(3,'output');
matrix.gpio.setMode(4,'output');
matrix.gpio.setMode(5,'output');
////////////////////////////////////THERE METHOD
methods.roboticarmThere = function() {
    for(i_0 = 75; i_0 <= 155; i_0++) {    // Rotating base servo
        matrix.gpio.setServoAngle({
            pin: 0,
            angle: i_0,
            min_pulse_ms: 0.2
        for(i_delay0 = 0; i_delay0 < 2000000; i_delay0++) {
            ///////////////// delay servo
    for(i_2 = 100; i_2 <= 135; i_2++) {    // Third axis servo
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
        for(i_delay2 = 0; i_delay2 < 2000000; i_delay2++) {
    for(i_5 = 105; i_5 <= 135; i_5++) {    // Mechanical claw servo
            pin: 5,
            angle: i_5,
            min_pulse_ms: 0.2
        for(i_delay5 = 0; i_delay5 < 2000000; i_delay5++) {
            ///////////////// delay servo pinza
    for(i_2 = 135; i_2 >= 100; i_2--) {    // Third axis servo
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
        for(i_0 = 155; i_0 >= 45; i_0--) {    // Rotating base servo
            pin: 0,
            angle: i_0,
            min_pulse_ms: 0.2
            ///////////////// delay servo base
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
    for(i_5 = 135; i_5 >= 105; i_5--) {    // Mechanical claw servo
            pin: 5,
            angle: i_5,
            min_pulse_ms: 0.2
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
        for(i_0 = 45; i_0 <= 75; i_0++) {    // Rotating base servo
            pin: 0,
            angle: i_0,
            min_pulse_ms: 0.2
   console.log("Robotic Arm Have Been Turned There");
////////////////////////////////////HERE METHOD
methods.roboticarmHere = function() {
    for(i_0 = 125; i_0 >= 75; i_0--) {    // Rotating base servo
            pin: 0,
            angle: i_0,
            // minimum pulse width for a PWM wave (in milliseconds)
            min_pulse_ms: 0.2
    for(i_1 = 90; i_1 >= 85; i_1--) {    // Second axis servo
            pin: 1,
            angle: i_1,
            min_pulse_ms: 0.2
        for(i_delay1 = 0; i_delay1 < 2000000; i_delay1++) {
    for(i_2 = 120; i_2 >= 100; i_2--) {    // Third axis servo
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
    for(i_3 = 135; i_3 >= 120; i_3--) {    // Fourth axis servo
            pin: 3,
            angle: i_3,
            min_pulse_ms: 0.2
        for(i_delay3 = 0; i_delay3 < 2000000; i_delay3++) {
    for(i_0 = 75; i_0 >= 45; i_0--) {    // Rotating base servo
            pin: 0,
            angle: i_0,
            min_pulse_ms: 0.2
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
            pin: 5,
            angle: i_5,
            min_pulse_ms: 0.2
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
        for(i_0 = 30; i_0 <= 155; i_0++) {    // Rotating base servo
            pin: 0,
            angle: i_0,
            min_pulse_ms: 0.2
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
            pin: 5,
            angle: i_5,
            min_pulse_ms: 0.2
            pin: 2,
            angle: i_2,
            min_pulse_ms: 0.2
    for(i_0 = 155; i_0 >= 75; i_0--) {    // Rotating base servo
            pin: 0,
            angle: i_0,
            min_pulse_ms: 0.2
   console.log("Robotic Arm Have Been Turned Here");
 Copy and paste this files into the /home/pi/lite_js folder of your Raspberry Pi board. You can download this files on the "Code" section.
Notes:
