Added assembly instructions on github
A project log for CM6 - Compliant 3D printed robotic arm
Cheap, Open-source, safe, and compliant 6 - Axis 3d printed robotic arm based on Quasi direct drive BLDC drives.
Petar CrnjakPetar Crnjak 09/13/2021 at 16:190 Comments
It will be updated regularly. Atm only mechanical assembly instructions!
https://github.com/PCrnjak/CM6_COBOT_ROBOT/blob/main/assembly_instructions_v1.pdf
