Home Assistant Addon
A project log for Openthread Sensor Tag
Open Design Ultra Low Power Sensor Tag for light, temperature, humidity and pressure. openthread on Zephyr with json to MQTT and Grafana
mirkoMirko 01/22/2024 at 08:330 Comments
Hey Folks! We have developed a new Home Assistant Addon to integrate the Thread Sensor Tag into Home Assistant which removes the need to use the Python script we provided.
With the Addon the Thread Sensor Tag data is received and translated into a Home Assistant Device showing you the data it sends. I wrote a little page on how to integrate the Addon and how to use it - it is really easy: https://hackaday.io/page/22298-home-assistant-addon-to-integrate-the-thread-sensor-tag
You can now also setup a OpenThread Border Router using Home Assistant and the nRFR52840 or the SkyConnect from HA.
Happy automation!
