MycoHub wiring design consideration update
A project log for MycoHub
A comprehensive mycology platform; a clean box, a lab incubator, a "smart" spawn and fruiting chamber with online data tracking for research
jonathanJonathan 07/16/2021 at 15:221 Comment
Intro:
I initially started this project intending it to be just the 'MycoBox', a raspberry pi monitored and controlled chamber for spawning and fruiting. However, I soon realized the MycoBox is nearly a perfect bench-top space for including a complete mycology lab as well! So, my wiring design is in need of an update.
Initial Idea:
I like to keep data and clock lines from my controllers to my sensors as short as possible, as a best practice I think, so I intended to place the raspberry pi in an insulated box inside the chamber right below the sensor pole ( front door pole that holds the CO2, humidity, and temperature sensors).
This way I could run relay wires under the floor and over to the relay panel out of sight, and run a few data lines neatly up the pole to the sensors.
New idea & why I'm changing the design:
Summary: The Raspberry Pi will live above the MycoBox and below the MycoLab in a ventilated access panel for easy construction and maintenance, instead of inside the MycoBox chamber.
Jonathan wrote 07/16/2021 at 16:36 point
I'll be uploading more info about the build so far, and the software of course!
