After a longer break I managed to draw the symbols and footprints of the SAML22G and the IR transceiver module, so I would not have to rely on licenses of external sources. With that I was able to finalise a first prototype board and send it to JLCPCB for production. With the recent pink PCBs that boardhouses now produce I was very tempted, but I opted for a set of 5 green PCBs instead. I decided to run the board on 2.5V, which makes it easy for the AP2112K to work with the battery voltages of a LiPo battery, without running into dropout voltages first. There is some room and I'm tempted to add a footprint for a compass chip in the future, but I can always just connect to the QWIIC connector, as long as they are okay with 2.5V. Should have thought about that.
davedarko
Ohooo, these look good!
Ordering boards is always exciting, and compact ones even more so.
Hopefully, it all goes well!
I'm also close to ordering the boards for my #TapV2 badge too, and that step of the project is always so nerve-wracking...
aww thanks! Good luck to you, too then! I'm actually relieved to have send something out, after such a long "break"
Thanks!
I have not ordered yet, and I am *really* glad I waited. I almost ordered the PCB with multiple of the ESP32 strapping pins misconfigured so it might not have booted or been programmable.
Strapping pins are such a nemesis when not marked well - I hope your boards go well and without requiring cut traces.
