Battery switch
A project log for F-16 Solder Kit
Easy to solder kit card style solder kit
Wim Van GoolWim Van Gool 07/27/2021 at 08:530 Comments
By popular demand, a new revision of the kit was created with a SMD switch added. This slightly increases the price, but if price is important a simple solder bridge can be made as well to bypass the switch. The SMD switch has small plastic pins in the PCB allowing for easier placement and soldering.
