• New version of Raspberry Pi TV Stick
    mbs05/08/2026 at 10:08 0 comments
    There is a newer version of the board, designed specifically for Raspberry Pi CM5:
    https://hackaday.io/project/205651-raspberry-pi-cm5-tv-stick-lite
    It’s available for purchase at Makerfabs:
    https://www.makerfabs.com/raspberry-pi-cm5-tv-stick-lite.html
  • Everything is better with LEDs
    mbs08/17/2021 at 14:22 0 comments
    WS2812 LED strip arrived and after some soldering works nicely
    Next will be testing WS2801
  • Pre-production boards
    mbs08/14/2021 at 00:40 0 comments
    Pre-production boards have arrived!
    Time to test ambilight connector.
  • Testing
    mbs07/31/2021 at 21:34 0 comments
    Tested built in IR receiver and to a big surprise it can receive signal despite of being behind TV and looking towards the wall.
    pi@raspberrypi:~ $ irw
    00000000e0e0e01f 00 KEY_VOLUMEUP remote
    00000000e0e0e01f 01 KEY_VOLUMEUP remote
    00000000e0e0d02f 00 KEY_VOLUMEDOWN remote
    00000000e0e0d02f 01 KEY_VOLUMEDOWN remote
    00000000e0e020df 00 BTN_1 remote
    Also tested with eMMC version of CM4 for flashing.
    To enter eMMC programming mode:
    • USB multiplexer selector switch to USB-C position
    • Press and hold User Button
    • Connect USB-C cable
    • Release User Button
    • Follow software procedure
    Still have to think how and where to fit connector or solder pads for Ambilight...
