Aneng M118A - PCB template
A project log for Hack into an existing Multimeter
Using the impact resistant case of a multimeter for your electronics Demonstrated on the design of a Zener-Tester / LED-Vf-Tester
Max SchnorpfeilMax Schnorpfeil 08/02/2021 at 11:350 Comments
The dimensions of the original PCB have been copied.
You can find the files here:  EasyEDA - Aneng M118A Template
PS: Note the beautiful pattern for the rubber buttons!
