CCD Driver Circuit Board Finished! (TCD1304DG)
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 04/07/2017 at 17:440 Comments
Well, I gotter' done, next will be testing after I burn the bootloader on this, and a few other tweaks;
The picture above is before placing the ADC (AD7667,) you can see the placement of the AD8021 op amp underneath the AD7667.
Finished product, the ADC (AD7667) placed on top of the AD8021 op amp, the TCD1304DG above and the ATmega1284 MCU to the left. (the MAX660 you can see off to the right.) I am powering this with a 12vdc 1A wall plugin pwr supply.
