*UPDATED* 8 Bit CCD Driver For TCD1304DG PCB Board
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 07/16/2017 at 15:010 Comments
Well, after careful consideration and inspection of my design I took the advice I was given and re-designed the entire circuit, I had to manually place the components on the board instead of using the auto placement feature in DesignSpark.
This may have been the problem, it arranges the components in the most optimal way yes, but does not take into account any analog to digital cross talk situations, if it does, I haven't found it, anyway's I finally got it done and did a 3D rendering also, which actually helped a lot in recognizing some further mistakes that I was able to rectify quickly.
So here it is:
( The blue lines represent bottom copper and the red lines are top copper in the image below)
