Turtle Prototyping Solder Board
180 tie-point solderable breadboard for electronics. Entry level soldering for kids in STEM.
Starting from
$6.00
Bits4Bots has 21 orders / 0reviews
Ships from United States of America
BREADBOARD General Purpose. Fun and unique turtle shaped tie-point prototype solder board. 8 SMD practice pads. 59mm x 79mm diameter. Hello makers. This project is designed to engage youngsters and allow them to tinker with their first electronics projects. Hardware designed with kids in mind. We believe things that look fun are fun and this turtle solder board is no exception!
Age
  • 6-13+
Features:
  • Eight 1206 (3216 metric) surface mount solder practice pads
  • Components NOT included.
  • Dimensions: 59mm x 70mm
  • PCB thickness 1.6mm
  • Green color
  • Unisex
  • 180 tie point. Isolated solder pad around each hole on both sides. Hole size 1mm (standard)
Environmental:
  • Material: FR4 Epoxy Glass { MIL - P13949 type Gf } 1.27mm pitch
  • Temperature range: -55ºC to +125ºC
Why did you make it?
To engage younger students and makers and to provide tools for electronics and hardware design. Bring something different & creative to market.
What makes it special?
First of its kind. Unique circuit board with personality.
View project log
  • 1
    How to use it:
    Each pad is isolated so that any combination of discrete components and chips may be inserted and soldered into place. Using point-to-point wiring will result in the most flexibility and highest density construction possible.
View all instructions
