Controller connectivity Issue
A project log for PSX2PTZ: PTZ camera control using PSX controller
Allows you to use a wireless PS2 controller for controlling PTZ cameras using RS485
deoscodedeoscode 05/21/2023 at 15:410 Comments
The code is designed to allow wireless controllers to connect after powerup. This seems to work "most" of the time. Occasionally a wired controller is not detected on power up (stays in Connecting... state), but requires a reset before it connects. Needs further investigation.
