The best way to test and illustrate new components is to put them into a "end to end" project. It is even better to be able to visualize what is happening, and for that purpose a video output component was reused from another project
Here is the somewhat simplified schema of the top level file of the project, which is at the same time the test circuit:
The "new and noteworthy" components are explained in the project logs. The dual port RAM is initialized with an image during build time (as is often the case with FPGA projects, for example, "firmware" for the system being implemented). During runtime, it can either be loaded with new HEX file stream, contents read as HEX stream, or both (not at the same time, switch(0) on Mercury board selects the mode).
Some other components visible on the schema:
Top level entity description defines the use of hardware resources on the board. A/D, PS/2 and audio in/out are not used.
entity hex_io_mercury is
    Port (
                -- 50MHz on the Mercury board
                CLK: in std_logic;
                -- 96MHz external clock
                EXT_CLK: in std_logic;
                -- Master reset button on Mercury board
                USR_BTN: in std_logic;
                -- Switches on baseboard
                -- SW(0) -- OFF: accept HEX input, ON: generate HEX output
                -- SW(1) -- OFF: TIM-011 video (512*256, 4 colors), ON: V99X8 video (256*192, 16 colors)
                -- SW(2) -- HEX_CLK speed sel 0 (000 = trace mode, tracer is active)
                -- SW(3) -- HEX_CLK speed sel 1
                -- SW(4) -- HEX_CLK speed sel 2 (111 = 12MHz)
                -- SW(5) -- ON: Enable character echo trace for HEXOUT
                -- SW(6) -- ON: Enable write to memory trace for HEXOUT
                -- SW(7) -- ON: Enable error trace for HEXOUT
                SW: in std_logic_vector(7 downto 0);
                -- Push buttons on baseboard
                -- BTN0 - HEX input mode: move window right    ; HEX output mode: start output
                -- BTN1 - HEX input mode: move window left    ; HEX output mode: increment mode register
                -- BTN2 - HEX input mode: move window down    ; HEX output mode: select uart_mode
                -- BTN3 - HEX input mode: move window up        ; HEX output mode: select uart_baudrate
                BTN: in std_logic_vector(3 downto 0);
                -- Stereo audio output on baseboard
                --AUDIO_OUT_L, AUDIO_OUT_R: out std_logic;
                -- 7seg LED on baseboard
                A_TO_G: out std_logic_vector(6 downto 0);
                AN: out std_logic_vector(3 downto 0);
                DOT: out std_logic;
                -- 4 LEDs on Mercury board (3 and 2 are used by VGA VSYNC and HSYNC)
                LED: inout std_logic_vector(1 downto 0);
                -- ADC interface
                -- channel    input
                -- 0            Audio Left
                -- 1             Audio Right
                -- 2            Temperature
                -- 3            Light
                -- 4            Pot
                -- 5            Channel 5 (free)
                -- 6            Channel 6 (free)
                -- 7            Channel 7 (free)
                --ADC_MISO: in std_logic;
                --ADC_MOSI: out std_logic;
                --ADC_SCK: out std_logic;
                --ADC_CSN: out std_logic;
                --PS2_DATA: inout std_logic;
                --PS2_CLOCK: inout std_logic;
                --VGA interface
                --register state is traced to VGA after each instruction if SW0 = on
                --640*480 50Hz mode is used, which give 80*60 character display
                --but to save memory, only 80*50 are used which fits into 4k video RAM
                HSYNC: out std_logic;
                VSYNC: out std_logic;
                RED: out std_logic_vector(2 downto 0);
                GRN: out std_logic_vector(2 downto 0);
                BLU: out std_logic_vector(1 downto 0);
                --PMOD interface
                --connection to https://store.digilentinc.com/pmod-kypd-16-button-keypad/
                PMOD: inout std_logic_vector(7 downto 0)
end hex_io_mercury;
