Info on the original car reversing kit MCU​
A project log for Wind sensor using car reversing kit
A wind speed and direction sensor from an Ebay car reversing kit and an Arduino
kwikiuskwikius 10/31/2021 at 11:330 Comments
In reply to https://hackaday.io/project/181677/discussion-169393
I  had  another  look at the mcu that I removed from my 2nd version of the car reversing kit and saw it had  chip markings on the underside. (N.B 2 pictures shown as for some reason the light obscures one or other dependent on angle )The markings say:
   FH511
   LON.1
However I couldn't find anything useful by googling that!
Here also are some closeups of the two footprints on the 2 different car reversing kit boards I have.
mcu footprint of first kit1 I bought
mcu footprint of second kit I bought
Here is why I think it might be a PIC12
The original MCU pinout ( based on the 8 pin footprint, but for both boards) v PIC12 footprint. I have only quickly studied the PIC12 datasheet and the pcb so data may be inaccurate!
pin numberPCB MCU functionPIC12F function
Pin1
5V
5V
Pin2Transducer address out bit0
RA5
Pin3Transducer drive
RA4
Pin4Pulse envelope detect
RA3. T1G Timer1 (16 bit timer) gate, so could accurately capture flight time
Pin5monitor power? monitor Clk?
RA2 SCL?
Pin6
monitor data IO ?
RA1 SDA?
Pin7 Transducer address out bit1
RA0
Pin8GNDGND
