Test #3: Ultrasonic sensor HC-SR04
A project log for Inverted pendulum on a cart
Building an inverted pendulum system with PID control. Trying to achieve swing-up.
dharshanDharshan 05/01/2022 at 09:200 Comments
Using a HC-SR04 ultrasonic sensor to track the position of the cart.
Limiting the minima to 10cm and maxima to 45cm (~10mm clearance)
I used a cardboard cut-out to mount the sensor, and also as a rebound surface,
Although the least count is 1cm here, the reading seems to be pretty precise.
