Wrastling I2C
A project log for AirQualSniff
amateur air quality sniffer and atmospheric science widget
jon-kunkeeJon Kunkee 11/23/2021 at 04:050 Comments
I2C ain't so bad: simple is as simple does. Vendor implementations and programming models? Those are...more of a challenge.
To change I2C bus speeds in Arduino environments, it turns out you have to set the speed before Wire.begin() is called. If you want to change speed, you have to call Wire.end(), change, and call Wire.begin().
I wrote up some other challenges I hit on my blog:
https://daskunkee.blogspot.com/2021/11/technical-ssd1327-oled-driver-on.html
