Blender gears
A project log for PROCESS DOCS
Some process docs about some work routines
3drobert3drobert 10/03/2021 at 19:070 Comments
http://www.valvias.com/prontuario-rosca-metrica-din-13.php?m=11
Linear pitch: 1.5mm
Tooths: 20
Adapt Pitch diameter multiplier to get Outside diameter (10mm)
Creating the screw
Creating the gear
Creating one screw nut
Creating the screw axis
Creating the gear axis
now I will indicate some tolerance corrections to perform simulations, machining or to make 3D printing
Sources:
https://www.metalmecanica-facil.mahtg.com/tsinfycor/calculador-tornillo-sinfin-y-corona.html
https://docs.google.com/spreadsheets/d/1aFcktbNmx7cTsuAU0JgZB2Xayx76sSm1ici_PpTlju8/edit?usp=sharing
CONF adjusting tolerances:
Reduce 10um gear axis diameter
Reduce 10um screw axis diameter
Down 10um nut tooth top  (1.125mm to 1.115mm)
Up 10um nut tooth top (0.375mm to 0.385mm)
Note: Make the same for the nut tooths
Now join the axis tooths
and nut tooths
and gear axis
20 tooths = 1:20 (around 75um per 1.5mm step)
reductor multiplier :)
1.5mm/20 = 75um
75um/20 = 3.75um
3.75um/20 = 187.5nm
187.5nm/20 = 9.375nm
If I place more of these I could do a kind of clutch disconnecting 2 and 3 and connecting 1 and 4 when apply some movement of joystick. I will need to handle micro-things in 2D/3D for future projects.
