This product update introduces new features added after the release of the PC-64 kits.
Intel NUC Support
A new bottom mount and rear I/O shield has been designed to work with the motherboard from an Intel NUC7i5BNK kit. These motherboards are more readily available and offer comparable performance to the Asus PN51 Mini PC's.
![](https://cdn.hackaday.io/images/5346121715812216175.png)
![](https://cdn.hackaday.io/images/9873501715812224244.png)
The controller port and controller adapter boards were re-designed to work with both Intel NUC and Asus PN51 versions, with the former now featuring a reset switch which the Intel NUC has provisions for.
![](https://cdn.hackaday.io/images/604511715812203154.png)
![](https://cdn.hackaday.io/images/6414261715812241717.png)
