3.0.2
- Return zero (-3) error fixed
3.0.1
- Define Min Limits (if reading value is smaller than limit return 0)
- Faster UART Connection
- Error Codes Updated (No Phase Selected = 0, Invalid Response Header = -1, Recieved Data Count or Checksum Error = -2, No Response = -3)
2.2.0
- All functions are sampled via Saleae
- Make updates for times
- Measure faster
- Added UART anaylses to extras
2.1.2
- Moved the repo to LVX
- Changed error code to (-1)
- removed abs function
2.0.2
- Returns absolute value (negative value error updated).
2.0.1
- Error variables updated.
2.0.0
- Library name changed
- Function names changed
1.2.0
- initial update
1.1.0
- Error variables added, -1001: Without Data, -1002: Negative Acknowledge, -1003: Command not implemented, -1004: Checksum failed
- Voltage function deployment.
- Voltage function name changed to RMS_Voltage
- New voltage function added INST_Voltage (Per Phase)
- New voltage function added RMS_Voltage_AVR
- New voltage function added FUN_Voltage (Per Phase)
- New voltage function added HARM_Voltage (Per Phase)
- New function added RMS_Voltage_MIN
- New function added RMS_Voltage_MAX
- Current function deployment.
- Current function name changed to RMS_Current (Per Phase)
- New Current function added RMS_Current_AVR
- New Current function added PEAK_Current (Per Phase)
- New Current function added INST_Current (Per Phase)
- New Current function added FUN_Current (Per Phase)
- New Current function added HARM_Current (Per Phase)
- New Current function added RMS_Current_MAX
- ActivePower function deployment. (Per Phase)
- New Current function added ActivePower_AVR
- ReActivePower function deployment. (Per Phase)
- New Current function added ReActivePower_AVR
- ApparentPower function deployment. (Per Phase)
- New Current function added ApparentPower_AVR
- New Current function added FundamentalPower (Per Phase)
- New Current function added HarmonicPower (Per Phase)
- New Current function added FundamentalVA (Per Phase)
- PowerFactor function deployment. (Per Phase)
- New Current function added PowerFactor_AVR
- Frequency function deployment.
- Temperature function deployment.
1.0.2
- IC Startup commands converted to HEX format.
- Voltage commands converted to HEX format.
- CommandSend function commands converted to HEX format.
- 'print' functions converted to 'write'
- Checksum equation converted to HEX
