The BleuIO is Bluetooth low energy USB dongle that can be used to create new BLE 5.0 applications in the fastest and easiest way. The BleuIO comes with a bootloader that allows you to update the firmware or flash your own application to the dongle.
This project has both USB CDC and BLE in Peripheral Mode. This allows you to create your own command interpreter that takes in commands to the Dongle via a serial terminal. You can then use this to execute BLE tasks such as start set advertsing or response data, start and stop advertsing etc.
