Audio Cape Design
A project log for Spotify Box Light
A device that can stream Spotify
PeroPero 10/19/2021 at 07:340 Comments
PocketBeagle has a SiP that contains TI AM3358 CPU that has no I2S. Instead, it has the McASP.  From the reference manual: "The multichannel audio serial port (McASP) functions as a general-purpose audio serial port optimized for the needs of multichannel audio applications. The McASP is useful for time-division multiplexed (TDM) stream, Inter-Integrated Sound (I2S) protocols, and intercomponent digital audio interface transmission (DIT)."
Hopefully, I don't need to write the code for McASP myself. I have found existing PocketBeagle add-on boards that provide audio outputs. There are two capes that kinda support audio outputs via McASP to interface the TLV320AIC audio codec. One is the Bela (on-going art/sound platform with fancy IDE), the other one is BB-BONE-AUDI (that seem to have disappeared from the market). They both have similar/same pin connections to the codec:
TLV320AIC3104 Connector AM3358
MCLK P1.29 PRU0.7 - MCASP0-AHCLK
WCLK P1.33 PRU0.1 - MCASP0-FSX
BCLK P1.36 PWM0A -  MCASP0-ACLKX
DIN P2.32 PRU0.2 - MCASP0-AXR0
DOUT P2.30 PRU0.3 - MCASP0-AHCLKR
RESET# P2.26 PMICGOOD
SCL P1.28 I2C2_SCL
SDA P1.26 I2C2_SDA
HW Project
I have modified an existing BelaMini Rev B4 Design, by adding a 3.5mm audio jack. It was a nice trip down the memory lane of using Eagle.
I have ordered PCBs from JLC-PCB. Since they also offer a cheap SMT assembly service too, I decided to let them do the soldering. There is a limitation, however, they only work with the components they have on LCSC stock. As you can guess, my chip TLV320AIC3104 is not stocked there. Fortunately, there was an alternative: TLV320AIC3101 - a chip with integrated speaker amplifier. Everything else is the same, and should to the job just as fine.
