In this IoT project, I have shown how to make an IoT-based Home Automation project using NodeMCU and the new Blynk app to control a 4-channel relay module from the manual switch & smartphone.
During the article, I have shown all the steps to make this Blynk home automation system.
Tutorial Video on new Blynk ESP8266 Smart Home
This Blynk ESP8266 control smart relay has the following features:
So, you can easily make this home automation project at home just by using a NodeMCU and relay module. Or you can also use a custom-designed PCB for this project.
Required Components:
You can make this project just by using NodeMCU and 4-channel relay module. But if you use PCB then you need the following components.
Required Components for the PCB
1. Relays 5v (SPDT) (4 no)
2. BC547 Transistors (4 no)
3. PC817 Optocuplors (4 no)
4. 510-ohm 0.25-watt Resistor (4 no) (R1 - R4)
5. 1k 0.25-watt Resistors (5 no) (R5 - R9)
6. LED 5-mm (5 no)
7. 1N4007 Diodes (5 no) (D1 - D5)
8. Push Buttons (4 no)
9. Terminal Connectors
10. 5V DC supply
Required Software:
1. Blynk IoT (Blynk 2.0)
2. Arduino IDE
Circuit Diagram of the NodeMCU Home Automation Project
This is the complete circuit diagram for this home automation project. I have explained the circuit in the tutorial video.
The circuit is very simple, I have used the GPIO pins D1, D2, D5 & D6 to control the 4 relays. And the GPIO pins SD3, D3, D7 & RX are connected with push buttons to control the 4 relays manually.
I have used the INPUT_PULLUP function in Arduino IDE instead of using the pull-up resistors.
I have used a 5V mobile charger to supply the smart relay module.
The D3 pin should not be connected with GND during the booting process of NodeMCU.
Control Relays Using Blynk IoT App
If the NodeMCU is connected with WiFi, then you can control the home appliances from Blynk IoT App.
You also use multiple smartphones to control the appliances with Blynk IoT App. For that, you have to log in same Blynk account from all the smartphones. In this way, all smartphones will be sink to the Blynk server.
You can control, monitor the real-time status of the relays from anywhere in the world with the Blynk App.
Control Relays Manually With Buttons or Switches
You can also control the relays from the switches or pushbuttons.
If the NodeMCU is connected with Wi-Fi then you can monitor the real-time feedback in the Blynk IoT App.
Please refer to the circuit diagram to connect the pushbuttons or switches.
Design the PCB for This Smart Home System
To make the circuit compact and give a professional look, I have designed the PCB after testing all the features of the smart relay module.
You can download the PCB Gerber file of this home automation project from the following link:
https://drive.google.com/uc?export=download&id=1Jx4D_DSV_ei1y0a82AbtxbsNhy8sjCmY
Order the PCB
After downloading the Garber file you can easily order the PCB
1. Visit https://jlcpcb.com/RHS and Sign in / Sign up
2. Click on the QUOTE NOW button.
3. Click on the "Add your Gerber file" button. Then browse and select the Gerber file you have downloaded.
Uploading the Gerber File and Set the Parameters
4. Set the required parameter like Quantity, PCB masking color, etc.
5. After selecting all the Parameters for PCB click on SAVE TO CART button.
Select Shipping Address and Payment Mode
6. Type the Shipping Address.
7. Select the Shipping Method suitable for you.
8. Submit the order and proceed with the payment.
You can also track your order from the JLCPCB
My PCBs took 2 days to get manufactured and arrived within a week using the DHL delivery option.
PCBs were well packed and the quality was really good at this affordable price.
Solder All the Components on PCB
After that, I have soldered all the components as per the circuit diagram.
Then connect the NodeMCU board with the PCB.
Create FREE Blynk Cloud Account:
For this smart house project, I have used the Blynk IoT Cloud Free plan.
Click on the following link to create a Blynk Cloud account.
https://blynk.cloud/dashboard/register
After that Blynk cloud dashboard will open.
Create a New Template in Blynk Cloud:
First, you have to create a template in the Blynk cloud.
You will get the BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME after creating the temple.
The BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME will be required while programming the NodeMCU.
Create a Datastream in Blynk Cloud:
After that, you have to create Datastreams. Here I will control 4 relays, so I have to create 4 Datastreams.
In a similar way, create 4 datastreams with virtual pin V1, V2, V3, and V4.
Set Up Blynk Cloud Web Dashboard:
Now go to the web dashboard tab.
Drag and drop 4 Switch widgets.
Go to the settings of each widget, and select a Datastream.
Install Blynk IoT App to Configure Mobile Dashboard:
Add Widgets in Blynk IoT App:
Program the NodeMCU for This Blynk Project
First, download the code from the following link.
Click Here to Download Code
Update the WiFi Credentials Through OTA
After programming the NodeMCU, you have to update the WiFi credentials from the Blynk IoT app.
In the tutorial video, I have explained all the steps to update the WiFi credentials to NodeMCU through OTA.
Testing the PCB
After the NodeMCU connects with the Blynk server, the WiFi indicator LED blinks very slowly.
Before connecting the appliances, please check whether you can control the relay from the Blynk IoT app.
Connect the Home Appliances
Connect the 4 appliances with the relay module as per the circuit diagram.
Please take proper safety precautions while working with high voltage.
Connect 5-volt DC supply with the PCB. (I have used my old mobile charger 5V 2Amp)
Turn on the 110V/230V supply and 5V DC supply.
Finally!! the Blynk Home Automation System Is Ready
Now you can control your home appliances in a smart way.
I hope you have liked this new Blynk home automation project. I have shared all the required information for this project.
I will really appreciate it if you share your valuable feedbacks. Also if you have any query please write in the comment section.
Thank you & Happy Learning.
