This is the first attempt at this shield, and it's mostly based on guesswork, datasheet, schematic for the ESP32 Cam board, and some bad quality images of the pinouts I found online. I have absolutely no idea if it will work, but I can try. The design is pretty dense:
I didn't feel like fixing the angles of all the traces, so you will have to suffer. The render doesn't look bad:
There are two voltage regulators, each with its own capacitor, two resistors for I2C pull-ups, a resistor to pull-down the enable pin on the camera, and a 14pF capacitor on the PCLK line, no idea why, but ESP32 Cam had it, so I copied it. And of course the camera socket itself, which is a fun 0.5mm-pitch footprint.
