Power supply input
A project log for Airborne radioboard
It is a hobby project main goal of which is to build a PCB board that can receive the GPS signal and send its location to the Ground Station
pavelPavel 11/21/2021 at 05:350 Comments
Here is the input power part. It consist of 2 parts, the USB mini for easy use and pico blade connector. In the flight power supply will be provided from the molex 1x4 connector through the LD1117* LDO that will convert voltage into 3.3V.
