Dock Printed!
A project log for EUfON FLT
MIDI Wind controller based on ESP32 via BLE.
ryecache-tianmeowryeCache TianMeow 11/09/2021 at 14:583 Comments
As follows,dock Printed.
Structure designed to control the incoming air.
A screw to adjust the pressure.
ryeCache TianMeow wrote 11/13/2021 at 15:08 point
It would be only a temporary solution.A screenshot's updated to a new log.
wapata.31 wrote 11/11/2021 at 08:45 point
Hi !
Do you have some other views of your pressure adjustment device ? I too would like to add screw tune, but your design seem.... Complex (like why so many channels ?).
ryeCache TianMeow wrote 11/13/2021 at 15:02 point
I just explain it.
The screw left is just for fixing.
The screw buttom right is for adjusting the blowing rate outside.Fastening it would make pressure higher.
The screw mid-right is nothing for right now.
The tune top connected to the pressure meter module.It's low-cast.
I'll update all BOM maybe in next version.
(Sorry for my LAZY head)
