I built a lux meter for my darkroom photolab.
It is used to measure intensity of light hitting the photopaper to reduce the chance of over or underexposing.
I plan to tint the case with a nice colour, write labels, add a knob to the switch, rebuild the sensor donge with a nice case and maybe try to (as good as it can be done without proper equipment) calibrate the scale.
you may know that already, but you could shrink the whole device considerably by using a brightness sensor like TSL2591 and a µC like RasPi Pico which drives then two or more 7-Segment-Displays.
Expenditures for such a device would be between 15€ - 20€, so, yes, probably more expensive than your system if you are using recycled parts.
Indeed my costs were very low, I think I only ordered opamp and diode for <5€, everything else including wood for the case was reused from scrap or old leftovers (which of course doesn't mean they are free).
One thing you do not want in your darkroom is a glowing display bringing more light into the dark which is why I opted for a big moving coil instrument. But I get your point, it does have benefits to not reinvent the wheel and use of the shelf sensors, one of them being calibration.
That's cool. 👍 Many decades ago, a light meter on the same principles increased my proportion of correctly exposed paper. Now all you have to do is couple it to a enlarger lamp timer.
For now it will be done by hand. But how could the light meter be coupled to the timer? It had to be in two steps I guess, measuring light intensity and calculating exposure time through a empirically selected factor. Then in the second step exposure the photopaper with the calculated time.
Hello Johannes,
Grüße aus Nürnberg
