Hardware-only solution
A project log for Deghosting multiplexed LEDs
LEDs also act as tiny capacitors and this can be a source of them lighting up when you don't want them to
mihaicuciucmihai.cuciuc 11/07/2021 at 16:260 Comments
John suggested an alternate solution that requires no changes to the software and no extra MCU pinL Precharge the LEDs by just connecting a fairly large-valued resistor from Vcc to the common line. I tried it out with a couple of 20k resistors and it works! Awesome!
Updated schematic:
