Open Light Switch V1.2 Prototype
A project log for Light Switch reverse engineered
So basically I bought a light switch and stole the circuit design to make it better.
setCREATEsetCREATE 11/27/2021 at 13:100 Comments
Log no.1: Open Light Switch V1.2 Prototype
What I've done?
I received the V1.2 PCB, soldered everything, and tested the circuit.
Images:
The Assembled PCB
This might be the worst quality you've ever seen for a PCB
Results:
Well, everything worked fine that's it.
Next Step:
I will update the PCB.
