Log no.1: Open Light Switch V1.2 Prototype
What I've done?
I received the V1.2 PCB, soldered everything, and tested the circuit.
Images:
![](https://cdn.hackaday.io/images/5564171638018387347.jpg)
The Assembled PCB
![](https://cdn.hackaday.io/images/5723531638018523037.jpg)
This might be the worst quality you've ever seen for a PCB
![](https://cdn.hackaday.io/images/3774151638018566638.jpg)
Results:
Well, everything worked fine that's it.
Next Step:
I will update the PCB.
