I have decided on a dual power supply, one for the Motors and their Drives and the other to supply the 'compute' aspects.
The 12V battery supply will provide for the Motors/Drive and the Lithium P for the compute.
These supplies need to be distribute and to save space I've created a 'Distribution Stack'.
This can be seen here.
![](https://cdn.hackaday.io/images/5325621640898542387.jpg)
Also to save space I've velcro'd the Lithium, the Lead Acid and the Solar Controller together.
Velcro is useful to tear things apart quickly.
![](https://cdn.hackaday.io/images/7006101640898646321.jpg)
These can now be connected together. You will note that one lithium battery is different, easy to change and replace because of the velcro.
![](https://cdn.hackaday.io/images/1336281640898730038.jpg)
You also see that solar cells for the Low Voltage supply connected.
While I haven't connected the Motors and Drivers up I have successfully connected the RPi and the Arduino boards and powered them up at the same time.
Not fully tested them but it does mean we are on our way,
