I cranked out a temporary neck mount and attached the head to the robot. It now is a full rolling chassis. From here I can add the electrical subsystem and get the motors wired up. Be a few more weeks till the robot is mobile but I'm making steady progress.
The neck will have to wait. I had some really nice steal cable springs I found on Electronic Goldmine, but for the life of me I can't find them now that I need them. Anyhow, the head should be a compliant mechanism (the tilting part) where it can at the very least turn left and right and also tilt. The tilting should allow it to express a confused look. (something I plan on it doing a lot if it does not recognize a command or hears a noise)
The uFactory lite 6, a 6 axis arm and batteries were placed for weight distribution. The batteries will be a good offset to the weight of the arm The arm comes in @ around 20 pounds in total, I'm ok with that as it has a built in controller and motor drives. It can also lift ~600grams of weight. Technical the robot will have a 7 axis arm as it will be on a linear rail and have a linear actuator raising and lowering it. This is so it can grasp things off the floor and also reach table height. The robot can't bend over like we can, so a engineering solution was devised.
![](https://cdn.hackaday.io/images/2977961703909009128.jpg)
![](https://cdn.hackaday.io/images/7433161703909451631.jpg)
