Using the iron
A project log for 40W Digital Soldering Iron Controller
Repurposing a bad 110VAC soldering iron station to make a 24VDC one that is digitally controlled.
ksudoubleeKSUdoubleE 08/20/2022 at 14:460 Comments
Haven't posted in a bit, but I've been using the iron.  I had to end up reading the temperature with the iron turned off, otherwise noise from somewhere affects the reading.  This seems to work pretty well.  I will post the circuit soon along with the code.
