"fixed" the Frequency Counter
A project log for Synthe555er
A simple monophonic Synthesizer based on the NE555
timoTimo 02/10/2022 at 23:161 Comment
Ok, so i have this old frequency counter, which would be perfect for trimming the keyboard but is also kind of dead. When i try to measure a known good source i only get a bunch of zero's and from time to time some flicker.
Luckily there is an easy to obtain service manual with a self test procedure and schematics (Yes they did this in the 80s, crazy right).
So i popped off the lid and followed the manual.
  1. open Device - "Allready did that."
  2. remove Jumper to get device to test mode - "Easy!"
  3. set switch on backside to 'use internal clock reference' - "..... Yeah, ... i should do that."
Turns out if you want to use an external reference source you kinda need one ... uppsi.
After setting the frequency counter back to its internal reference it worked great. I wonder if that was the reason why it was thrown out by its previous owner.
Ken Yap wrote 02/10/2022 at 23:41 point
👍 Isn't it a great feeling when fixes are this easy and something that seemed useless works again?
