How to add the GGreg20_V3 ThingSpeak channel sensor to the Home Assistant server
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
iot-devices-llcIoT-devices, LLC 07/27/2022 at 18:250 Comments
If you have a controller with a GGreg20_V3 radiation detector module that periodically sends data to the ThingSpeak server, you can also easily connect it to your Home Assistant server as well. In this publication we will look at why this might be necessary and how to do it.
Full Article: https://iot-devices.com.ua/en/how-to-add-the-ggreg20-v3-thingspeak-channel-sensor-to-the-home-assistant-server/
