GGreg20_V3 with Raspberry Pi Pico W under Home Assistant with ESPHome firmware config example
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
iot-devices-llcIoT-devices, LLC 07/18/2023 at 20:250 Comments
We’ve been planning to post a GGreg20_V3 configuration example for the Raspberry Pi Pico W since ESPHome started supporting this wonderful controller with wireless support. But after users started making projects for RPi with GGreg20_V3, and after Tom’s Hardware wrote about a project using Pico W, we also made our own full-featured configuration example.
Read the full story here:
iot-devices.com.ua/en/ggreg20_v3-with-raspberry-pi-pico-w-under-home-assistant-with-esphome-firmware-config-example-en/
Easy Links
go.iot-devices.com.ua/geiger-counter
go.iot-devices.com.ua/github
