initial commit
A project log for Kossel
AKA PooPooPanda, this is my custom RepRap based on the kossel design. It's perpetually being modified and never actually works.
reiddyeReidDye 12/29/2021 at 22:340 Comments
Here's what the printer looks like now:
It used to be a Sintron Kossel Mini (link), but I've made many modifications.  The original kit was not great.  I got it in late 2016, just as I was starting 6th grade, but got stuck after finishing the main hardware assembly.  The wiring diagrams didn't match the provided electronics (standard RAMPS 1.4), the instruction manual was a pirated out of date pdf, there was no explanation about how to set up the firmware, etc.  It was terrible.  After a few months of trial and error, I got frustrated and shelved the project.  I bought a prusa mk2s (now a mk2.5s!) that has served me well since.  But then, in late 2019, I picked it up again, and with the reprap knowledge I'd gained, I was able to get it printing.  I've been making lots of iterative improvements to it ever since. Here it was, with the minimum modification needed to print:
Since then, I've:
That's a lot of changes!  But there's more to come. I'm currently working on:
With these changes, I want to try printing a <10 minute benchy!  I know I'm pretty late to the #speedboatrace, but it'll still be fun.
Anyway, that's the current status.  I'll write more logs when I make some progress!
edit: I wanted to add a picture of the intermediate effector design.  I changed the stock effector to this, then this to the current quick-change effector.
The main reasoning behind this was that the stock bed probe was offset from the nozzle, so the effector tilt caused by any imperfections in the build completely messed up the probing.  In this design, the probe is the nozzle itself, so that problem was eliminated.  I was also able to add part cooling with this design, which was a huge plus.
