Prototype-1 and its internals
A project log for Kagedourou: Ghost in the lantern
A traditional lantern with a digital ghost.
likeabloblikeablob 01/02/2022 at 16:590 Comments
So, here is a prototype-1, made by sacrificing my year-end holidays.
I hope it makes some laughs on its finishing which is comparable to 4th-grade-homework-crafts-thing.
(I admit it's due to 1. my gibberish hands 2. my old Kossel k800 FDM printer. But instead of learning hand crafts and replacing k800 with a new SLA printer, I would try online printing services such as JLCPCB or FusionPCB. HP Jet Fusion 4200 with Nylon PA12? What a tech xxxx.)
Internally this prototype-1 uses the following components:
And here is my work log (for myself);
That's it. Then it's time to power the OPi on.
------ cut here ------
To draw a dynamic silhouette onto a surface, the following ways are in my mind;
For A: LCD, recently Hi-Res (1080p+) LCDs with HDMI interface boards are available at (relatively) inexpensive prices,  mainly for replacement parts for hobbyist-grade SLA printers.
 (pros) Does not require an optical system and thus space effective compared to B. Projector.
 (cons) It's probably difficult to handle multiple surfaces, especially for a resource-limited SBC. (It's still possible to go with a low-res LCD?)
If we go with a full-color LCD w/ backlight, another light source will be required for non-LCD sides of the lantern.
By using a monochrome, backlight-less LCD, we can unify the light source in the lantern and it save some hassles on tone matching between two different light sources.
