//#define CAYENNE_DEBUG
#define CAYENNE_PRINT Serial
#define DHTTYPE DHT11
#define DHTPIN  14
#include "CayenneDefines.h"
#include "BlynkSimpleEsp8266_mod.h"
#include "CayenneWiFiClient.h"
#include <DHT.h>
// Cayenne authentication token. This should be obtained from the Cayenne Dashboard.
char token[] = "TOKEN";
// Your network name and password.
char ssid[] = "SSID";
char password[] = "PASSWORD";
//Variables for DHT11 values
float h, t, hif;
bool Humidity = false;
bool Temperature = false;
bool HeatIndex = false;
DHT dht(DHTPIN, DHTTYPE);
void setup()
  Serial.begin(9600);
  Serial.print("Setup");
  Cayenne.begin(token, ssid, password);
  Humidity = false;
  HeatIndex = false;
void loop()
  //Run Cayenne Functions
  Cayenne.run();
  //Check if we got all values we wanted and sleep for 10 minutes if we did
  if (Humidity && Temperature && HeatIndex){
    Serial.println("Got all values - sleeping");
    delay(100);
    ESP.deepSleep(60000000, WAKE_RF_DEFAULT);
    delay(100);
CAYENNE_OUT(V0){
  Serial.println("Entered Humidity");
  //Check if read failed and try until success
  do {
    //Read humidity (percent)
    h = dht.readHumidity();
    delay(1000);
  } while  (isnan(h));
  Serial.print("Humidity: ");
  Serial.println(h);
  //Set Humidity to true so we know when to sleep
  Humidity = true;
  //Write to Cayenne Dashboard
  Cayenne.virtualWrite(V0, h);
CAYENNE_OUT(V1){
  Serial.println("Entered Temperature");
  do {
    //Read temperature as Fahrenheit
    t = dht.readTemperature(true);
    delay(1000);
  } while  (isnan(t));
  Serial.print("Temperature: ");
  Serial.println(t);
  //Set Temperature to true so we know when to sleep
  Temperature = true;
  Cayenne.virtualWrite(V1, t);
CAYENNE_OUT(V2){
  Serial.println("Entered Heat Index");
  do {
    //Calculate Heat Index as Fahrenheit
    hif = dht.computeHeatIndex(t, h);
  } while  (isnan(t) || isnan(h));
  Serial.print("Heat Index: ");
  Serial.println(hif);
  //Set HeatIndex to true so we know when to sleep
  HeatIndex = true;
  Cayenne.virtualWrite(V2, hif);
To deal with wireless connectivity issues you can create a copy of BlynkSimpleEsp8266.h in your sketch folder with a modified connectWiFi function. Below is my solution to the ESP staying awake and draining the batteries when it cannot connect to the configured wifi network. If the ESP fails to connect 30 times it's safe to say it probably won't. In that case I have the ESP go in to sleep mode for 5 minutes before it tries again. Save the text below to a file called BlynkSimpleEsp8266_mod.h in your sketch folder and instead of importing BlynkSimpleEsp8266.h import BlynkSimpleEsp8266_mod.h.
 * @file       BlynkSimpleEsp8266.h
 * @author     Volodymyr Shymanskyy
 * @license    This project is released under the MIT License (MIT)
 * @copyright  Copyright (c) 2015 Volodymyr Shymanskyy
 * @date       Jan 2015
 * @brief
#ifndef BlynkSimpleEsp8266_h
#define BlynkSimpleEsp8266_h
#ifndef ESP8266
#error This code is intended to run on the ESP8266 platform! Please check your Tools->Board setting.
#endif
#ifndef BLYNK_INFO_DEVICE
#define BLYNK_INFO_DEVICE  "ESP8266"
#endif
#include <BlynkApiArduino.h>
#include <Blynk/BlynkProtocol.h>
#include <Adapters/BlynkArduinoClient.h>
#include <ESP8266WiFi.h>
class BlynkWifi
    : public BlynkProtocol<BlynkArduinoClient>
    typedef BlynkProtocol<BlynkArduinoClient> Base;
public:
    BlynkWifi(BlynkArduinoClient& transp)
        : Base(transp)
    void connectWiFi(const char* ssid, const char* pass)
        int timeoutcounter=0;
        BLYNK_LOG("Connecting to %s", ssid);
        WiFi.mode(WIFI_STA);
        if (pass && strlen(pass)) {
            WiFi.begin(ssid, pass);
        } else {
            WiFi.begin(ssid);
        while (WiFi.status() != WL_CONNECTED) {
            timeoutcounter++;
            if (timeoutcounter >= 30){
                BLYNK_LOG("Failed to connect to wireless - sleeping for 5 minutes");
                delay(100);
                ESP.deepSleep(300000000, WAKE_RF_DEFAULT);
                delay(100);
            ::delay(500);
        BLYNK_LOG("Connected to WiFi");
        IPAddress myip = WiFi.localIP();
        BLYNK_LOG("My IP: %d.%d.%d.%d", myip[0], myip[1], myip[2], myip[3]);
    void config(const char* auth,
                const char* domain = BLYNK_DEFAULT_DOMAIN,
                uint16_t    port   = BLYNK_DEFAULT_PORT)
        Base::begin(auth);
        this->conn.begin(domain, port);
                IPAddress   ip,
        Base::begin(auth);
        this->conn.begin(ip, port);
    void begin(const char* auth,
               const char* ssid,
               const char* pass,
        connectWiFi(ssid, pass);
        config(auth, domain, port);
               const char* ssid,
               const char* pass,
               IPAddress   ip,
        config(auth, ip, port);
static WiFiClient _blynkWifiClient;
static BlynkArduinoClient _blynkTransport(_blynkWifiClient);
BlynkWifi Blynk(_blynkTransport);
#include <BlynkWidgets.h>
#endif
What's Connected
ESP-12f
1000uf Capacitor
PCB Headers
Jumper Wires
Single Sided Perf Board
DHT11
2 AAA battery holder
Triggers & Alerts
I set up a trigger to email me when the temperature drops below 65 (cold) and another trigger to email me when the temperature is above 90 (hot). Triggers and Alerts come standard with Cayenne platform.
UPDATE: This lasted just over 1 month! Continuing to modify and improve!
