Testing and Tuning the PID
A project log for SMD reflow hotplate
simple smd reflow hotplate based on *MCH Metal Ceramic Heating* elements
stefan-krgerStefan Krüger 01/08/2022 at 11:320 Comments
for tuning i followed more or less the tutorial PID Without a PhD from Tim Wescott and the tutorial and video from PID Explained Team.
first i just checked with low temperatures of 20..40°C as i went on and tested up to 260°C i noticed that the current did decrease. and the temperature did not increase any more. i could see this in my graph as the heating got slower and slower with the rising temperature… (also the pid already saturated at the output..)
so i measured the resistance during the cool down of the heating elements to get some insights: (4x in series → 48V/4=~12V/Module)
Resistance (Ohm)Power @48V (W)
4057
3958
3859
3660,5
3860,3
3464,8
2688,6
2496
22104
20,9110
19,5118
Temperature / Resistance – 4 Modules in Series – 12V/Module
result: the ~57W is not enough to get to more than 255°C…
i rearranged the Modules into 3-in-series connection. this means ~16V/Module – and tested again:
27,570
27,072
26,677
25,680
25,382
24,186
18,8100
17,5130
16,7
15,6
14,3
Temperature / Resistance 3 Modules in Series – 16V/Module
with this i found that i can go above 255°C.
i then tested the profile for the Felder ISO-Cream “Clear” and found that in the reflow stage the heat-up is a little to slow:
config:3S profile:Felder ISO-Cream “Clear”
my setup
in the *my setup* picture is a temporary cardboard thing with a 80mm 12V fan (connected to 5V) to cool down faster between tests. for the final setup i think i will buy 1 or two 5V and PWM capable fans…. and also exchange the *chamotte* ston with some metal frame. this way i also can cool the bottom side..
so i again switch the configuration – now i have a 2-in-series config: 24V/Module CURRENTLY THIS TABLE IS ONLY CALCULATED VALUES!!
20115
19,5118
19121
18128
17,5132
17135
13177
12192
11209
10,45220
9,75236
CURRENTLY ONLY CALCULATED VALUES!!!! Temperature / Resistance – 2 Modules in Series – 24V/Module
i also tested this with the Felder profile:
this time the heat-up is fast enough! 🙂 the nice and working pid tuning i had for the 4-in-series arrangement is now out of tune… so i will have to re-tune it to get less overshoot / swing.
while having a break i thought about the maximal power in this configuration – and found that this way i only be able to power 2×2 modules with my 250W power supply. for now i leave it this way. in the long run i hope with the other frame concept i get more heat to the pcb and less into the stone and this way be able to use the 3S config.
Tuning
after a day of mostly waiting til the system cooled down again – one test cycle <=60°C needs 400s → 6:40min – i just rebuild my hw mounting setup.
this way i can warm up quicker and cool down much quicker as i do not store heat in the stone. – at least that is what i hope..
plot old setup
plot with old setup
plot new setup
plot with new setup
hmmm – does not seem to change much..
i then tested the actual Felder Profile:
Felder ISO-Cream ‘Clear’ – Sn96,5Ag3,0Cu0,5 – 2S1P – P 04.50 I 00.00 D 00.00
seems i have a working profile. i will add a little more time for the prepare phase. so the pcb is really fully at the 50°C. at the top i have a little bit of a mis-match – i saw on my temp sensor directly connected to the heating elements at the top ~265°C – so that is hot… the pcb seems to increase its temperature resistance at higher temperatures… at the peak i have 230°C to 245°C error. and to the heating this results in ~35°C difference…
i will report when i solder the first real board. 😉
