MAX8815 Step up converter
In this project I wanted to make a step up converter based on the high efficiency MAX8815 integrated circuit. MAX8815 is a great component!
Public Chat
This step-up converter has the following features: Input: 1.5V - 5V Output: 5V fixed or 3.3V - 5V (adjustable). The max output current depends on input voltage. the board goes into protection when the input current exceeds 1A This circuit is useful for powering a 3.3v - 5v circuit (such as a microcontroller) through a lower voltage battery, such as: lithium cell, LTO cell, Ni-cd, etc ... Max8815 is a high efficiency circuit: this feature is essential in a battery powered system, where every single mA saved is important for the battery life! I decided to share this project to allow everyone to use, try and experience the MAX8815 IC. The project is shared on Github and open to modifications and improvements.
Max8815  board
Max8815 board is Step-up converter based on MAX8815.
The project is designed according to MAX8815 data sheet:
https://datasheets.maximintegrated.com/en/ds/MAX8815A.pdf
The circuit has the following features:
Input: 1.5V - 5V
PCB production.
The board was made by PCBway.
I decided to order the pre-assembled PCB with the SMD components.
The result was excellent.
I greatly appreciated the assistance with continuous communication on the progress of the production.
Before shipping, they sent me photos of the product, to receive my "ok": this is very important!
Where to buy.
if you want to test this circuit, you can purchase the PCB pre-assembled with the smd components  at the following link:  https://www.pcbway.com/project/shareproject/MAX8815_step_up_converter_7f76c33b.html
It is possible to purchase  only the PCB if you prefere
Instructions.
5V Fixed output:
  1. Set J3 shunt to "OFF" position
  2. Set J4 shunt to "Normal" position
  3. Set J5 shunt to "5v" position
  4. Connect Input power supply (range 1,5v - 5v)
  5. Set J3 shunt to "ON" position
  6. Check D1 led lights ON
  7. Connect the output load
Adjustable output:
  3. Set J5 shunt to "Adj" position
  7. Set the output voltage (from 3,3v to 5v) by RV1 potentiometer
Other settings:
By J4 shunt it is possible to set "FPWM" mode according to MAX8815 data sheet
Opensource development application.
The project was created using Kicad
Opensource Hardware certification.
Max8815 board has been certified as open source hardware by the Open Source Hardware Association, with the UID: IT000008.
License.
This work is licensed under a Creative Commons Attribution-ShareAlike 4.0 International License. https://creativecommons.org/licenses/by-sa/4.0/
Green_BMS_max8815_00.pdf
Electrical diagram
Adobe Portable Document Format - 71.22 kB - 01/12/2022 at 10:00
Preview
View project log
