Table with hall sensor output voltage relative to phase voltage (aka six step configuration - current step). Zero phase voltage indicates that phase is not driven by transistor half-bridge.
Visual representation of table above.
A project log for RUDDOG RP691 2200kV characterization
Since datasheet for this BLDC motor is not available, I will try to characterize its properties and share it here.
