Table of Contents
1 Introduction
This is the documentation of some experiments I performed in order to ascertain whether it's possible to detect cells generating excessive heat (aka "heaters") in a diy 18650 battery pack built using the popular 5x4 20.2 mm pitch 18650 cell holders. All of the findings should be applicable to bigger cell arrays as well.
2 tl;dr
By using an array of LM75 temperature sensors attached to one side of a 18650 cell pack abnormal heating of a single cell to a temperature of at least 50 deg Celcius results in a measureable (2 deg C) temperature anomaly which may allow for heater detection before a major pack failure has chance to occur.
3 Experimental setup
The experimental setup consists of a fake "pack" built out of 20 no-name 18650 cells connected (spot-welded) to a short strip of the 5P continuous nickel fuse roll from batteryhookup. The cells were welded only on the positive side with a small heater attached to the negative side of a single cell in order to simulate a "heater" cell. The cells used were junk cells having 0V and no charge in them for safety. The following image illustrates the experimental setup:
The heater assembly consists of a 10 Ohm / 5W resistor attached to the negative side of a single cell with thermally-conductive adhesive. A MOSFET is used to regulate the current flowing through the resistor with PWM. An K-type thermocouple is attached to the cell next to the heater resistor in order to for a closed feedback loop to stabilise the heater temperature. The temperature from the thermocouple is being read using a MAX6675 breakout board. The top PCB contains five LM75 I2C temperature sensors soldered in a very simple chain:
The temperature sensors are labeled U1-U5 and their relative locations can be seen on the PCB silkscreen. The location of the fake heater cell is indicated with the "HEATER LOC 1" text. During the experimental runs the temperatures read from U1-U5 sensors are logged into a CSV file for analysis. The assembled experimental setup can be seen below:
4 Software
The experiment is being controlled by an Arduino sketch which performs the following functions:
The code for the Arduino project can be downloaded for reference. The most critical part (the main loop) is shown below:
void loop() {  float temp = thermocouple.readCelsius();
  float deltaT = target_temp - temp;
  float pwm_drive = min( max(deltaT * P, 0), 1023);
  // read temperatures for the ZIF-20C-TEMP board  float temp_U1 = U1.readTemperatureC();  float temp_U2 = U2.readTemperatureC();  float temp_U3 = U3.readTemperatureC();  float temp_U4 = U4.readTemperatureC();  float temp_U5 = U5.readTemperatureC();
  Serial.print("target_temp[degC] = ");  Serial.print(target_temp);  Serial.print("\ttemp[degC] = ");  Serial.print(temp);  Serial.print("\tpwm[%] = ");  Serial.print(map(pwm_drive, 0, 1023, 0, 100));  Serial.print("\tU1[degC] = ");  Serial.print(temp_U1);  Serial.print("\tU2[degC] = ");  Serial.print(temp_U2);  Serial.print("\tU3[degC] = ");  Serial.print(temp_U3);  Serial.print("\tU4[degC] = ");  Serial.print(temp_U4);  Serial.print("\tU5[degC] = ");  Serial.print(temp_U5);  Serial.println();
  analogWrite(heaterON, pwm_drive);  // For the MAX6675 to update, you must delay AT LEAST 250ms between reads!  delay(300);
The data printed by the Arduino code was monitored, plotted and logged using QtSerialMonitor which I unfortunately had to build from source code myself. An example data point gathered in the CSV file is presented below:
"time","target_temp[degC]","temp[degC]","pwm[%]","U1[degC]","U2[degC]","U3[degC]","U4[degC]","U5[degC]",
2022-01-09T15:01:18.890Z,70.000000,24.750000,100.000000,22.500000,23.000000,23.000000,23.000000,22.500000,
The columns convey the following information:
###td
>td ###Celcius
###td
>td ###Celcius
Column name Value description Unit Notes
time timestamp ISO-8601 UTC
targettemp[degC]
temp[degC]
pwm[%] current PWM output >td ###Rescaled from 0-1023 to 0-100>#/td###
U1[degC] current temperature for the U1 sensor Celcius
U2[degC] current temperature for the U2 sensor
U3[degC] current temperature for the U3 sensor
U4[degC] current temperature for the U4 sensor
U5[degC] current temperature for the U5 sensor
5 Experimental runs
There were 3 experimental runs performed with different temperature setpoints for the heater but otherwise identical circumstances. Ambient temperature was not controlled but can be seen in the initial readouts from U1-U5 before the heater power supply was switched on. Each experimental run consists of four phases:
The phases are not explicitly marked in the data but can be noticed when observing the relationship between pwm[%] and temp[degC]. When the heater power supply is switched off (in the baselining and cooldown phases) the temperature does not rise even though the PWM output is 100%. The summary of experimental runs with raw data linked are provided below:
Experimental run Heater setpoint Raw data Notes
Run 1 70 09.01.2022_15.47.18.318Z_Log.csv
Run 2 60 10.01.2022_14.57.09.844Z_Log.csv
Run 3 50 11.01.2022_10.23.06.399Z_Log.csv
6 Data analysis
The goal of the experiment is to ascertain whether an array of simple temperature sensors attached to a 18650 cell pack can successfully detect and/or locate a cell experiencing abnormal heat generation during charging or discharging.
6.1 Detecting a heater cell
In order to move towards this goal first some analysis was done on the raw data to check if there is any difference between the temperatures detected by particular sensors in order to detect an anomaly. A Python script was developed for this purpose and ran against the gathered CSV data dumps:
import pandas as pd
import numpy as np
columns = [ "time","target_temp[degC]","temp[degC]","pwm[%]","U1[degC]","U2[degC]","U3[degC]","U4[degC]","U5[degC]" ]
data = pd.read_csv(csv_filename, usecols=columns)
data['min_temp'] = data[['U1[degC]', 'U2[degC]', 'U3[degC]', 'U4[degC]', 'U5[degC]']].min(axis=1)
data['max_temp'] = data[['U1[degC]', 'U2[degC]', 'U3[degC]', 'U4[degC]', 'U5[degC]']].max(axis=1)
data['temp_anomaly'] = abs(data['max_temp'] - data['min_temp'])
print(f'Data from {csv_filename}:')
print(data)
print('Temperature anomaly:')
print(data['temp_anomaly'].describe())
6.1.1 Experimental run 1
Data from in-situ-18650-heater-detection/09.01.2022_15.47.18.318Z_Log.csv:                           time  target_temp[degC]  ...  max_temp  temp_anomaly
0      2022-01-09T15:01:18.890Z               70.0  ...      23.0           0.5
1      2022-01-09T15:01:19.198Z               70.0  ...      23.0           0.5
2      2022-01-09T15:01:19.507Z               70.0  ...      23.0           0.5
3      2022-01-09T15:01:19.815Z               70.0  ...      23.0           0.5
4      2022-01-09T15:01:20.123Z               70.0  ...      23.0           0.5
69266  2022-01-09T21:01:52.570Z               70.0  ...      25.5           1.0
69267  2022-01-09T21:01:52.875Z               70.0  ...      25.5           1.0
69268  2022-01-09T21:01:53.193Z               70.0  ...      25.5           1.0
69269  2022-01-09T21:01:53.491Z               70.0  ...      25.5           1.0
69270  2022-01-09T21:01:53.797Z               70.0  ...      25.5           1.0
[69271 rows x 12 columns]
count    69271.000000
mean         2.648713
std          0.707099
min          0.000000
25%          2.500000
50%          3.000000
75%          3.000000
max          3.500000
Name: temp_anomaly, dtype: float64
6.1.2 Experimental run 2
Data from in-situ-18650-heater-detection/10.01.2022_14.57.09.844Z_Log.csv:                           time  target_temp[degC]  ...  max_temp  temp_anomaly
0      2022-01-10T14:01:10.676Z               60.0  ...      23.5           0.0
1      2022-01-10T14:01:10.982Z               60.0  ...      23.5           0.0
2      2022-01-10T14:01:11.289Z               60.0  ...      23.5           0.0
3      2022-01-10T14:01:11.595Z               60.0  ...      23.5           0.0
4      2022-01-10T14:01:11.903Z               60.0  ...      23.5           0.0
42364  2022-01-10T18:01:02.073Z               60.0  ...      26.5           0.5
42365  2022-01-10T18:01:02.379Z               60.0  ...      26.5           0.5
42366  2022-01-10T18:01:02.691Z               60.0  ...      26.5           0.5
42367  2022-01-10T18:01:02.996Z               60.0  ...      26.5           0.5
42368  2022-01-10T18:01:03.301Z               60.0  ...      26.5           0.5
[42369 rows x 12 columns]
count    42369.000000
mean         1.864240
std          0.648193
min          0.000000
25%          1.500000
50%          2.000000
75%          2.500000
max          2.500000
6.1.3 Experimental run 3
Data from in-situ-18650-heater-detection/11.01.2022_10.23.06.399Z_Log.csv:                           time  target_temp[degC]  ...  max_temp  temp_anomaly
0      2022-01-11T10:01:06.960Z               50.0  ...      25.0           0.0
1      2022-01-11T10:01:07.269Z               50.0  ...      25.0           0.0
2      2022-01-11T10:01:07.586Z               50.0  ...      25.5           0.5
3      2022-01-11T10:01:07.883Z               50.0  ...      25.0           0.0
4      2022-01-11T10:01:08.188Z               50.0  ...      25.0           0.0
58714  2022-01-11T15:01:39.845Z               50.0  ...      26.0           0.5
58715  2022-01-11T15:01:40.154Z               50.0  ...      26.0           0.5
58716  2022-01-11T15:01:40.462Z               50.0  ...      26.0           0.5
58717  2022-01-11T15:01:40.767Z               50.0  ...      26.0           0.5
58718  2022-01-11T15:01:41.075Z               50.0  ...      26.0           0.5
[58719 rows x 12 columns]
count    58719.000000
mean         1.545079
std          0.538658
min          0.000000
25%          1.500000
50%          1.500000
75%          2.000000
max          2.000000
As expected the observed maximum anomaly is larger when the heater setpoint is hotter:
Run Heater setpoint [degC] Maximum temperature anomaly Notes
Run 1 70 3.5
Run 2 60 2.5
Run 3 50 2
6.2 Locating the heater cell
The knowledge of the sensor board geometry and layout against the cells in the pack may allow for estimating the approximate location of a heater cell.
