More decoding
A project log for Reverse engineering of an unknown 868MHz protocol
Reusing old 868 MHz equipment in openHAB
hebel23hebel23 08/26/2023 at 18:510 Comments
It is long time ago, but today I had a little bit time to go ahead with my investigations.
After some playing with URH I found out, that the sensor bit per sample must be 1200.
So I have two decoded sensors with the following values
9B49B6D249A6D249268
D26D24D249B4D249268
