The goal of this project is to generate energy from sunlight. To accomplish so, we'll build a two-axis solar tracker system with several light sensors. The device will track the source of light and harvest the energy using its solar panel. The technology will then be able to store clean solar energy for later use.
robotistan
electronicsworkshops
ASHUMHRPROJECTS
