WIRING CONNECTIONS:
//     Activation switch - D5
//   SD ADAPTER:
//     GND
//     VCC - 5V
//     MISO - D12
//     MOSI - D11
//     SCK - D13
//     CS - D10
//   INA219:
//     VCC - 5V or 3V3
//     GND - COMMON GROUND
//     Scl - A5
//     Sda - A4
//     External:
//     Vin- Power IN (or Voltage tap - V is monitored related to GND)
//     Vin+ Power OUT (in series ONLY)
//     GND - to Common Ground
---------------------------REFERENCES ----------------------------
//   https://learn.adafruit.com/adafruit-ina219-current-sensor-breakout/wiring
//   https://diyi0t.com/ina219-tutorial-for-arduino-and-esp/
//   https://learn.adafruit.com/adafruit-data-logger-shield/using-the-real-time-clock-3
//   https://github.com/flav1972/ArduinoINA219
--------------------------- CODE AS FOLLOWS -----------------------------
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <INA219.h>
INA219 monitor;
// CONSTANTS and VARIABLES:
const int chipSelect = 10;
#define LOG_INTERVAL 1 // ms between entries
#define SAVE_INTERVAL 15000 // ms between data flushes to SD card
#define Switch 5    //switch connected to pin
bool active = HIGH;  //switch to record or not
File logfile;   //SD card file reference thing
uint32_t syncTime = 0; // time of last sync()
uint32_t START_TIME = 1; //variable to record when logging starts
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
void setup() {
  pinMode(Switch, INPUT_PULLUP);  //initialize activation switch input pin
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    while (1);      //if initialization fails it goes into an infinite loop (ded)
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  char filename[] = "LOGGER00.CSV";   //moved earlier so filename is global
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i / 10 + '0';
    filename[7] = i % 10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  Serial.print("Logging to: ");
  Serial.println(filename);
  logfile.println("Time (ms),voltage (V),current (mA)");  //These are the headers for what's being logged.
  monitor.begin();    //this initializes the INA219 circuit.
  // setting up our configuration
  //  monitor.configure(INA219::RANGE_16V, INA219::GAIN_2_80MV, INA219::ADC_64SAMP, INA219::ADC_64SAMP, INA219::CONT_SH_BUS);
  // calibrate with our values
  //  monitor.calibrate(SHUNT_R, SHUNT_MAX_V, BUS_MAX_V, MAX_CURRENT);
void loop(void) {
  if (active == LOW) {   //if switch is on (pulled to GND), then run logger for duration.
      // log milliseconds since starting
      uint32_t m = (millis()-START_TIME);
      logfile.print(m);           // milliseconds since start
      logfile.print(", ");
      float VOLTAGE = monitor.busVoltage();  //GET VOLTAGE READING
      float CURRENT = monitor.shuntCurrent() * 1000;    //GET CURRENT READING in Amps
      logfile.print(VOLTAGE, 3);
      logfile.println(CURRENT, 1);
//        Serial.print("shunt current: ");
//        Serial.print(monitor.shuntCurrent() * 1000, 1);
//        Serial.print(" mA     ");
//        Serial.print("bus voltage:   ");
//        Serial.print(monitor.busVoltage(), 3);
//        Serial.print(" V     ");
//        Serial.print(m);
//        Serial.println("ms");
      // delay for the amount of time we want between readings
      //delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));   //Verify this code later, maybe just add a dumb delay?
      delay(LOG_INTERVAL);
    active = digitalRead(Switch);   //update switch position.
    //restart loop when this parameter is matched, otherwise flush cache:
    if ((millis() - syncTime) < SAVE_INTERVAL) return;
    syncTime = millis();
    logfile.flush();    //save changes to SD card without closing file.
    Serial.println(">>> file saved <<<");
    return;
    Serial.println("---- WAITING ----");
    //  Serial.println("Waiting to start");
    delay(2000);      //starts within 2s of switch being activated
    active = digitalRead(Switch);   //read switch position.
    START_TIME = millis();
    Serial.println("~~~ resetting start time ~~~");
